Fireplace inserts....
ylomnstr
354
Staatsburg, NY
So, I'm redoing my basement and I currently have an old propane fireplace insert down there which I plan on using, but I'm curious how a new install would happen? All the photos I see online for these inserts have no exposed pipe. Isn't it code to have a shutoff valve inside somewhere? Otherwise, I would just be able to drill through the back of the fireplace and run the pipe directly to the rear of the insert. What am I missing here?
First of all is the "old propane insert" in a fire place?
2nd, sounds like your "OPI" is a Room-vented (AKA vent-free) unit.
If it is, you may want to think about whether or not you REALLY want to use it.
Read some of the "Vent-Free" postings here & then decide.
As far as a shut off, are you talking about the venting or the gas supply?
Venting has no shut off...
Gas supply shut-offs are required by code...
Please elaborate a little or tell us what model you're talking about.
Thanks for the reply. I originally posted here which you can check out for pics and specifics of what I have. https://www.hearth.com/talk/threads/37966/
The way it's currently setup is a line coming in from outside for the propane to the stove. The vent goes up the and out the chimney of the fireplace currently with a cap on top.
OK. I remember this one after looking at the pics.
Where did the old copper line attach to the unit?
Why can't you run new gas line the same way?
It goes behind the black surround. I did put in new black steel pipe and got rid of the old copper stuff. My question is, in the photos you see online, how do they have an insert and no pipe or shutoff valve inside the house. Or at least, that's how the pictures show it.
Generally, there a shut-off under the unit within a foot of the gas valve, in
the gas feed line.the last five feet or so is generally done with flexible stainless steel so you can
work with it in the confined space under the firebox & still get your connections
tight.
I would suggest you consult with a local pro. Its hard to help and explain things properly on here and we cannot physically see everything.
