Hi all - I've been reading the forum posts for awhile as I got ready to install a new wood insert. I was hoping to make my first post a review of the medium flush insert from FireplaceX but I've also run into an issue or two I was hoping to get some insight on.
First the review: The unit was installed last December 2019 in our 1200 sqft two story Cape Cod in south Minnesota with the maiden voyage taken on Christmas Day. I hired out the installation and a stainless steel liner was put through my 25' foot external chimney with no block off. After the first couple of slow burns to break it in the unit worked great. I would fire it up from cold and the cat thermometer would reach operable temp in 15 minutes or so. It drafted well and I would close the baffle and slow the air to get a great show from the secondaries - my oldest calls them ghost flames. The whole house is heated pretty well with no input from the furnace down into the single digits outside.
I haven't found a good way to take firebox temps so have been relying on the cat thermometer, for better or worse. I had that up to 1300 degrees once but have otherwise kept that between 900 and 1100 for the most part. I could get around 4-5 hours of good heat from a load of seasoned red elm that tests at 17-20% on my $10 meter. I'd wait until the ember bed had depleted a bit before reloading and the wood would take off pretty quickly and be back up to cat temps within 10-15 minutes. Up to this point I have been very satisfied with the unit.
Now the other side: A couple of weeks ago I noticed the secondaries were not as prevalent and we didn't see the ghost flames nearly as much. The fire seems to burn less evenly with most heat looking like its generated at the center of the stack of logs and its been harder to get it up to running temp. Even when it is humming it seems like it does not throw off as much heat. It takes longer to start from cold and on a re-load; I have to really baby it to get it hot enough to close down the baffle (or flu? still working on terminology). Its been largely a weekend heater so it hasn't seen anything near 24/7 use. I pulled a couple of the tubes and the baffle and the latter is warped about 1/2" across the span with one of the tubes being out of round as well.
It seems like a draft issue but I haven't been up to the top yet to see if creosote build up in the span of 6 weeks is the culprit though that seems unlikely. It's possible there is something else blocking up top, but I'm wondering if the warped baffle (possibly from overfiring) or something else around the insert could be the issue.
Any thoughts would be very welcome.
My bad there, but it does look like you could use a straight connection and a new cement job.
