Firewood wall pass-through (air lock)
bogydave said:
Mine goes into an unfinished basement, into a wood box, into the stove.
About 10 days worth (when it's cold)
1 row, stacked 4'6" high X 6' long 18" splits (roughly 1/3 cord (+/-)
I empty the stove right before a new load comes in & the ash
bucket goes out the opening.
Now using 7 lag bolts with washers to hold the insulated door on but to be a hinged door, it's
on the "to do " list. when I figure out how to do it. Bolts are a PIA. I use a drill & it's workable.
But it helps keep the house cleaner.
Holds 2 trailer loads.
Nice setup. Kind of reminds me of a coal chute.
Semipro said:
Now if I could only figure out a system for using pallets and my front end loader to load the pass-through...
I don't know, I think your system is just about perfect and it looks good on both sides. If you had your loader at a nice working height, how long and how much effort would it take to fill the pass-through? And, you don't have to worry about a little sway in a tight space with the front end of your tractor in the snow or slop.
Very cool bookshelf/wood storage . . . there's probably a reason for this . . . but why didn't you simply put the hinge on the side instead of at the top of the outer door?
I think you've found the bug in any plans to use pallets and the tractor; I'd probably damage the structure with the tractor when the wheels or my hands slips.
I'm just going to stick with the the FEL without pallets for now.
The door is pretty heavy and I was concerned about sagging, fit, hiding the hinges, and stresses on the structure. I also though it might be nice to have a roof over my head while loading.
I'll get some pics of mine tonight and post them.
sorry it took so long. My memory isnt what it used to be.
This was in the house when we bought it, so I cant take credit. But it is the cats hindend for keeping the dirt to a minimum and having the wood close to the Summit. (we did install the summit in the existing fireplace). This pass through goes into a hallway from the garage to the basement. So I keep a weeks worth of wood in the garage and fill this bin every morning. I really like it and would have no idea what to do if it wernt there.
  • Firewood wall pass-through (air lock)
Reactions: planner steve
OUr house had a built in area to the left of the fireplace with the same idea in mind. Door on the outside and one trimmed out wainscotting on the inside. THe problem for us was that when it was built there was no house to the the east of us. No that landscaping has matured and a homeis to our eaast it makes the door worthless since you cannot drive up to it with a trailer and in the winter that side of the house is not accessible by vehicle or wheel barrow.
When I recovered the chimney exterior with vinly siding after removing improperly installed facsia (cast stone with water intrusion from not having a wicking system in place). I also removed the exterior access door at that time as well since the design allowed water to get behind the door and was creating a water issue to the structure. So that is all corrected now.
We leave a trailer full in the garage and bring in muck bucket of wood in when burning and it works better and faster than the door thing ever did for us.
Cool Very nice Job!
I am think about how I want to build a cabin in the next few years at the farm. Since I am going to store the wood in the basement I am thinking of making a dumb waiter to lift my wood up and next to the stove.
Billy
Our neighbor has one that goes from his lower level into a cabinet right next to the stove in the living room on the main floor. It is sweet.
This seems to be the way to do it. One load in the tractor almost fills it and is pretty easy to transfer. The chains I had to install on the tractor made a world of difference too.
Although overall not going out at night to haul in wood is better I do still kind of miss the experience... except for the one night when that coon tried to shinny up my leg. :)
