I'm having problems with my Fisher Honey Bear stove.
I'm using seasoned wood, but fires seem to go out easily, sometimes can be smoky in the stove.
I'm concerned it is not drafting well, yet everything is fine with the flue, chimney and no significant creosote buildup.
So, I am concerned about 2 spots. First, the slit right inside the door (pictured) where I can see the vent rod going in and out has a lot of ash that I can't suck out with a vaccuum. Is that a problem? Is it blocking my air intake? If so, how to clean?
Second, there is the baffle plate (pictured) that sits on some supports between the burning area of the stove and the flue. I assume it originally was flat and it is warped. Question is, is it better to replace this with the curve going up (sits closer to the flue and maybe impedes updraft?) or curve coming down in the middle (which would cut into the area where I can put wood).
Thank you.
![[Hearth.com] Fisher vent and internal metal slab questions [Hearth.com] Fisher vent and internal metal slab questions](https://www.hearth.com/talk/data/attachments/268/268084-cbd408015481556e704df67d1dad54ad.jpg?hash=WXHxsFFcob)
Thank you.
