Foundation is poured and about to begin framing a shop with boiler room.
EKO 60 is ordered to heat house and shop.
Tried downloading the EKO manual to figure out optimal chimney size........couldn't read the small print, and I probably wouldn't have understood it anyway.
I'm planning on a masonary chimney with conventional flue. Chimney will be inside and about 26' tall.
Initially I was going to go with an 8" x 12" flue.......I thought the bigger the flue, the better the draft, but after reading some posts it sounds like the flue can be too big.
Would I be better with an 8"x8"??
Looking for some suggestions.......thanks!!
go with an over-sized flue, especially for a gasifier. basic physics means that if you send something meant for an 8" round flue into a much bigger rectangular flue, it will slow down, and build up crud and condensation, which will be bad for everything and everyone concerned. gasifiers have even less residual heat in the flue gas (than old time wood appliances) to help the flue gas rise through and out of the chimney, and oversized flues have caused a lot of trouble with "1970s" semi-airtight wood stoves (like in the 1950s chimney of my house) , so don't repeat others' problems.
