Hi all. After my experience with rust in my open tank, I've decided to do away with the flat plate heat exchanger and go to either copper or Pex coils. My reasons are this:
1. 1 less pump to run which means electricity saved and longer run-time on battery power during a power outage.
2. No need for rest chemicals ($100 for my 1200 gallons storage) and no need for maintenance on said chemicals. Just an occasional ph check.
3. Ability to heat DHW for the house more efficiently in summer than the current setup of pumping water out of storage, through heat exchanger into system plumbing, then into house and through another heat exchanger and pump before heating hot water..... The current way uses 5 pumps vs using 1 pump to circulate DHW through it's own dedicated copper coil.
4. Better stratification as my current system mixes the water up too much and these old milk tanks produce some issues with remedying that.
5. Less heatloss from tank as the current setup thermosiphons and will reduce 120 degree tank water to 60 degrees within 4 days.... (And this is an insulated tank, with extra R38 rolled insulation piled on top of it.)
So, how much should tubing should I use? I'd like to go copper if I can swing it. I NEED to be able to sink the full output of my new EKO 60 into this as I'll be heating the storage during summer for DHW purposes, and there wont' be other heat loads. I realize that once the tank starts getting warmed up, that I'll have some idling going on, but I'd like that not to happen until the top of the tank is around 150 or so....
So, what's the recommendation? I assume 1/2" tube would be best, with multiple coils in parrallel as more of the water is in contact with the walls of the tube vs large diameter tube.
My gut feeling says 300 feet of copper or 1200 feet of pex would work. For the DHW loop, one 50' loop of copper or 200 feet of pex.......
Am I on the right track here?
But, I'm willing to do that to save money. Plus, the thing will be self supporting in the tank too...... (I'll probably still use a soft copper coil for the DHW.)
