We have been burning here in South Jersey 24/7 since Christmas and burning fairly steady before then. I don't remember a winter this cold and can't imagine living in some of the northern climates. Brrr…. Needless to say, we are so happy that we purchased the Fireview last Spring.
I woke early this morning as I couldn't sleep, and contemplated cleaning the ashes/coals, cat, screen, and glass on the stove as well as a general vacuuming. It's been around six weeks since the cat was vacuumed and I noticed the stove was burning differently - erratic and somewhat cooler. After cleaning out the coals I pulled the cat. Yes it needed a vacuuming and since I had an empty squirt bottle, vinegar, and some mineral free battery water decided to give it a good shower after the vacuum. Used nearly a quart of the 50/50 solution then rinsed with the mineral free water.
Back to hearth I started vacuuming the area around the bypass and cat opening. The screen needed a good cleaning as the sides were probably 80% clogged and the front about 30%. All clean, the cat is dry, I reinstalled everything.
Hoping to see a big difference in performance, I grabbed a ¼ round of a SuperCedar some kindling and relit the Fireview. Added a few more small splits and it was coming back to life. It was breathing way better! I experimented with the draft control all the way down to .5 - no flames but the cat was glowing red. I added a couple more splits and had the top up to 620 deg - no flames - no smoke. I am a very happy camper.
