Good deal for a Stihl 036 pro?
hydestone
91
I found a Stihl 036 Pro for $300 that is in great condition (supposedly). I have not seen it yet. Do you think this is a good deal?
What about this compared to a new 290 for 359?
If it runs good in the cut yes not a bad deal at all! the o36 is alot better saw than the 290(you can compare the 036 to the new 361)
Ditto, I'll take my 034 over a 290. As a matter of fact, my bro in law has! (he owns a 290, I, a 034...he borrows my saw all the time)
$300 is a good deal if it runs/cuts well & has good compression
This is what the guy told me about the saw:
Hi, I can't take pictures right now. My camera is not working now. The saw was had a new cylinder and piston installed and seals and crank checked. It has a new bar and chain. I just finished the saw Saturday evening and tested it. It looks and runs great. The only thing I noticed was the chain creeps a little so I ordered new clutch springs for it which I'll install Friday when they come in. I don't know the true age but it's in nice condition. It was run on straight gas and had low compression. I want $300 for the saw.
Low compression.
Reactions: Pallet Pete
Low compression.
Had low compression,Just make 4 or 5 cuts if it runs good through out the cuts its good to go!(new rebuild!) Yea
mtfallsmikey said:
I gave $130 for an 036 at an aution this past summer...new bar/chains....really rocks!
I think that price is a bit salty.
That saw new 589.00
Exactly my point...$300 for a saw w/low compression
What's a new piston/cylinder....whatever else may ail it...let's say $200. Then, you have $500 in a used saw.
My 036 was a good find, altho bar/2 chains/air filter was as much as I paid for the saw.
might read that again the new piston is in "was low compression"
EXPLAIN. was it " the new piston was put in and after a compression check was done to reveal still having low compression" or "a new purposfully built low compression piston was put in to run on lower grade fuel. big difference.
mtfallsmikey said:
Nobody I know has ever heard of a "low compression" piston for any Stihl. Factory recommends 93 octane...end of story.
I'll second that...
A rebuilt 036 is a much better saw than the 290. If it looks presentable and runs good grab it up.
I'll third that.
I was confused as to the description, sorry to all for that. if it has new bottom end/cyl./piston, then $300 is good. I don't use my 290 anymore after scoring the 036!
