Great fun with the chinese clone 372XP
Highbeam
21,499
Mt. Rainier Foothills, WA
In my part of the country most of us process firewood in the dry months of summer. This year's log load came in a big end dump trailer picked in and out with a grapple. The logger prefers this because he can use his flat nose tractor, doesn't need to find 40 foot logs but can fill it up, and maybe cheat, with shorter random sections. Last time it was a full 40' long log truck of maple logs. Hardwood burning is pretty great. This year it's about 80% red alder with the rest maple.
This is also the first log load processed with the new chinese holzfforma G372XP I bought on amazon to back up the dolmar 6400 that is now obsolete and parts are becoming not available. Very similar saws and both use the same bar and chains. The 372xp currently costs $234. I've got to say that I really like the china saw. It's a clone of a great design with tons of aftermarket support. I learned how to tune a 2 stroke carb, and with a good load finally burned off some muffler paint.
The thing about using big saws on big long logs is that you can make a lot of rounds really fast. The picture of rounds was processed from logs to round in 3-4 hours. The mingo marker is still working extremely well and I also recommend that if you've never used one.
Filled up the 5 cord 2026/2027 bay of the woodshed and now I'm splitting for the neighbor and probably extra to sell. Red alder is really red when it first bleeds after cutting. It's not sticky but does leave your hands orange!
  • [Hearth.com] Great fun with the chinese clone 372XP
I didn't think Alder got that big. Is Alder an easy splitting wood? What kind of Maple - Big Leaf?
This was really big for alder. That’s a 28” bar and I needed to cut from both sides on some rounds. In the wild I’ve only ever seen 18” or so. The bottom of the big alder tree is definitely tough to split but the rest, away from large branches, is really nice splitting. Like maple really. And yes, our maple is big leaf. This year’s 5 cords is about 80% maple mixed with 20% fir. I don’t mind a mix and these hardwoods burn clean and have thin bark.
I’m sure tamarack and oak would be better but these are what we have.
Chinese saws seem to be hit or miss, I have a 20” bar Wemars, which is a beast! I also have a 28” bar FARMAC knock off of a MS381, which is a complete POS. I’m actually in the process of getting replacement power head (after I already got a replacement clutch)… so I guess at least the Amazon sellers are honoring warranties.
Happy cutting, I’m glads you got a “good one”; hopefully my replacement power head is good. If not I’m gonna modify it, until it’s a beast.
Reactions: Highbeam
I figured it was worth a gamble. Everything outside of the engine cases is easy enough to replace or upgrade if I ever needed to. Turns out it’s a kick butt saw.
Reactions: Turbo89
Yea, that’s where my head was at too. I wanted a bigger saw, but it’s hard ti justify $1000+ fit something on only going to used 5-10 times a year.
I guess these things love a base gasket delete and exhaust; so I’ll probably try that with the new head unit after I break it in.
Nice! Good to see you getting it done without breaking the bank!
Could you explain please, what is a base gasket delete and exhaust? I'm a poor chainsaw mechanic, but I do try. I'm also thinking about getting a clone and would like to know as much as I can before diving in
Deleting the gasket between the cylinder and the case, use sealant instead, has the effect of reducing the size of the combustion chamber so compression goes up and so does power. I suggest to first try running the saw as designed before making changes like that.
Reactions: Turbo89
When removing the base gasket on a saw you should check the squish area for clearance by using solder on the piston on 4 spots.
Place the solder on the top of the piston close to the edge with a bit of grease to hold it place.
Install the cylinder,turn over the saw slowly to compress the solder. remove the cylinder and measure the thickness that the solder compressed to. that is what your squish clearance will be. To close and the piston will contact the top of the cylinder causing damage.
Reactions: Turbo89
So a base gasket is the gasket where the cylinder head meets the cylinder block. You remove the head and take the gasket out; then replace it with silicone RTV. It’s less thick so you get a bump in cylinder compression ratio.
The exhaust mods range from drilling the muffler out (removing internal baffles) and adding extra holes, to buying or fabricating a new one for less restriction. I guess this really “wakes” the saw up, but of course is louder. Often you remove the flame arrester… so just be aware if you’re concerned about that.
Another modification is advancing the timing. This involves removing the flywheel and filing the key to slightly advance timing. I haven’t don’t this personally, but I’ve read about 1/4 of a keyway thickness is all you need.
