Forecast was for a low of 40, we hit 38. I had to do :D a shoulder season beak in fire to take the chill off. This was the second fire in the Englander. The first was shortly after it was installed to check out the install.
Outside temperature is way off for some reason. Outside temperature was 56, inside is correct.
I lit off the Englander. Since its so big and on the warmer side I did a 1/4 super cedar in front and a 1/4 one in back.
(broken image removed)
Getting going
Cat is enjoying the entertainment he missed all summer long.
Now he's cooking
That's more like it.
Coaling
Ending temperature upstairs, again the outside is WAAAYYY off.
Stove top peak temperature with the IR thermometer was 557. I was quite impressed with the stove.
Sent from my Nexus 7 using Tapatalk 2
Getting going
Now he's cooking
Coaling
depending on how good of gassification I have. I had heard about the doubling it to get inside temp. You just confirmed that within a pretty close range. So now I know I should have an inside temp of 450-600 degrees. Late last season I did away with my black pipe inside my basement from my ash cyclone in order to keep the temps higher in my 27' chimney off of my boiler. I installed double wall insulated S.S., another sack of money
, but worth it. I have not had any creosote since. We will see how this winter goes with it. Thanks for those pics. I like that heat meter, or whatever you call that fancy do hickey thinga ma bob ya got dere. (broken image removed)
