Hammer hot ones our truwood
charles z
10
Spring grove pa
What every one opinion one what pellets are better hammer hot ones our truwood . I have a quadefire classic bay 1200 . Iam new to pellets stove got it install and march used tsc pellets in didn’t like them any feed back would be great hanks
Reactions: Ssyko
Hamer Hots produce very good heat for a hardwood.. downside is u will get lot of ash...
same with barefoot, Tru-wood. But those 3 are much better than most box store hardwoods..
Reactions: Ssyko and charles z
should mention that I burn softwoods most of winter due to lowest ash and higher btu than hardwoods.
the hardwoods i burn are for early fall [ or shoulder season] when the real cold has not surfaced yet/.
Reactions: Ssyko
Actually, I was going to ask the OP if there were any premium softwood pellets available there. I believe it is all mostly hardwood.
I burn Eastern Embers and it is softwood. It is excellent. I would never switch.
Reactions: Ssyko
I work the other way around, a 50/50 blend, fall and spring, and Cubix hard wod during the cold
months. Cubix has a greater BTU than the Fusion Blend 50/50 both made by the same flooring company in Quebec
Ok thank you . I can get awf . American wood fibers our easyblaze also
I looked up those EZ Blaze pellets. The specs look look like mine which are made from spruce,fir and pine. That is what I would burn if I was down there. I think they are even better than mine as they are "Super Premium"
