Hello, I have a 2010 Harman accentra insert, purchased used about 3 years ago.. I replaced the circuit board and exhaust probe when I bought the stove.
Two nights ago it wouldnt light, but I lit the stove manually and all seemed fine.
I swapped out the igniter and when I turned the stove back on, the combustion fan runs and then a 2 blink code on the status light.
Combustion fan will run when I turn the stove off and only stops when I disconnect power.
I put the old igniter back in, same problem, fan runs, 2 blink status light.
I checked all the wiring, blew through the pressure switch tube, checked the fines box and the exhaust probe, all gaskets seem fine, door gasket passed the dollar bill test. Combustion fan spins freely, and runs when I turn the stove on, sounds normal.
My chimney liner is 6’ of stainless pipe, up my masonry chimney, as required by code in my state.
I put a brush a few feet up there and knocked some ash out, but not so much that makes me think there’s an issue with a blockage.
The stove ran perfectly up until it failed to light, but was fine after I manually lit it.
Any suggestions?
Thanks in advance…
Any suggestions?
Thanks in advance…
