Last night I woke to the smell of smoke. The stove was off so I went down and saw the ash pot filled with fresh pellets. I also noticed a little burnt ash outside the stove below the glass. There was also smoke in the stove. I cleared the pellets from the ash pot and started the ignition process again (forgetting to check what code was blinking). Ignition was slow and the pot was nearly filled with pellets again and there was an audible pop though this time the pellets ignited. I toggled the switch to disable and stove is running fine now as it always has.
This is the 5th winter I have used the Harman, and I have always run Woods and Sons pellets. I go through two tons a season so this stove has burned a total of 8.5 tons of pellets. During the day I use the disable setting so the stove does not cycle on and off (except during late fall/early spring where I run the auto (thermostat setting). At night while sleeping I do run the thermostat setting.
My research suggested that a failing ignition is the likely issue and I do have a replacement I could install, but I wanted to check here in this forum if there was some other possible issue and if other Harman P43 users have experienced this. Stove is direct vented, there is no air intake. Door seal is original but is tight. Ash box is about 1/4 full and I am right at the time where I would shut down the stove and do a thorough cleaning though it has been so cold this year that that "warm" cleaning days have been in short supply.
