There was a blinking light that I did not recognize. Someone in Youtube suggested to just clean the ESV probe, but now I still have that blinking light and a new more serious problem, the igniter does not want to heat up anymore. Any suggestions?
A 4 blink would for sure. That code means it's not reading the room temp probe so it goes into shut down mode but I believe the igniter would work when the stove is set on stove temp mode.
Yes, both of them would. #3 requires a "reset" (unplug stove for a couple of minutes then plug back in). #4 "should" correct itself when the issue is taken care of, but I would do a reset anyway once you have cleaned the ESP and made sure all its connections are correct and tight..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
