I am including Reference Data that I have collected on this issue.
I am dealing with weld-induced distortion (heat shrinkage) on the door stove face
around the latch mechanism. When heavy welds were applied above and below a
specific point on sheet steel , the intense heat caused the metal to expand. As the
welds cooled, they contracted sharply, pulling the metal inward and causing the
"sunken" or collapsed look in between them, while simultaneously pushing a bulge
outward on the door facing at the weld
Weld #1 Horizontal across top of latch pocket (Bulged)
Weld #2 Horizontal across metal frame work internal below door, I think this is for
air wash for glass (Bulged)
If you put straight edge across both these bulged welds at the same time you will
see the concave , sunken door face along latch area. I have measured this across 4 diff stoves. 2 of the stoves were new display models and 1 stove was replaced and the 4th stove is the replacement I received 2 weeks ago. DOM 08/26 It would be good to see all older P68 measurements. my results range from .063 on warr stove to .041 on other 3 stoves. stove body in this area is only 1/8 in sheet steel.
