I just purchased a Harman PF100. Built Nov 2003.
I completely cleaned the unit, checked/tested the ignitor, the ohms reading was good.
When I try to run an auto light it feeds pellets for about a minute then stops. Then nothing happens, no igniter light at all. After about 14 minutes it starts feeding pellets again and the burn pot is already overloaded with pellets and dropping into the ash pan.
I manually started it and it seemed to work fine, I ran a half a bag through it.
Any ideas? I did check the ESP and it seems fine, within range. Made sure the dip switches were correct. Not sure why it hasn't even tried to ignite or even illuminate the light on the circuit board? No status blinks either.
Thanks
Triclark03
Thanks
Triclark03
