Hello All,
I have a Harman P61-2 pellet stove and I am having a vacuum issue. The auger wouldn't start until I bypassed the vacuum switch. This has led me to be sure it is a vacuum issue that won't allow my stove to feed.
I have cleaned the stove recently, and even did another clean when this issue occurred. My only thoughts are two things: 1) My door gasket needs to be changed 2) My vacuum switch needs to be replaced.
Are there any other ideas anyone has that would be causing this?
Side Note: When I turn my door handle all the way to tighten it, the door seems loose and the dollar test fails. But when I turn the handle once around to loosen it a little and then close the door it makes a tight seal and passes the dollar test. Does the door handle not being tightened all the way effect the seal??
it worked!!
