Nice hearth! It looks happy sitting there. Why two thermometers on the flue instead of one on the stove top and one on the flue pipe?
I knew I was going to get that...off season, I cleaned the top of the stove offNice hearth! It looks happy sitting there. Why two thermometers on the flue instead of one on the stove top and one on the flue pipe?
Most of our cold months are 20-30, we dip down lower but usually only for a few days. getting to the occasional -3How severe are your winters? Once November/December roll around do you see the mercury get above freezing? I've heard those mountain states can have totally different climates just traveling a couple hours.
If you have a 6000 sq foot house and you're using less than 3 cords through a rather severe winter - I think you've just about maxed out your efficiency. What were you hoping for? To just pick up one of those bundles at the convenience store and heat through the winter on that?
We did not design the house, if we did it would have had 8"pipe. It is not just drilling the hole, but a steel sleeve has to be put through the wall, and the one that is there has to come out ;( Yes, we like to see fire, however with the extended fire season I am not sure that my husband hasn't had his fill of it for the year!Well, there's always this: http://jaroby.com/index.php?page=fiche&no=26&cat=1
I have skimmed both threads, and see statements of "6000 sq.ft.", "4400 sq.ft. finished", and "7400 sq.ft. total". There's a lot of range in those numbers, but in any case, I can't imagine heating a house that size from a single "space heater".
Then again, I can understand why you did not choose a boiler or furnace, as we chose against that ourselves. My figuring is that if I'm going to work that hard to scrounge, cut, split, and move all that wood, I want to look at a fire, damnit!
Why would you not have a multiple stove plan for a space that expansive? No matter how many BTU's you generate in the room with the stove, it must be difficult to circulate that heat to the far reaches of that home.
You want me to go to France to get a stove The numbers are not exact and for the winter, there are parts of the house we don't try to heat....so...Well, there's always this: http://jaroby.com/index.php?page=fiche&no=26&cat=1
http://weather-warehouse.com/WeatherHistory/PastWeatherData_CedarCity5E_CedarCity_UT_January.htmlI've looked at the NC 30 manual and specs....no expert here, but the firebox is 3.5 cu ft, and the co records in house testing resulting in 75000 BTU's per hour (doesn't give any details of the testing, or of burn times per load). The PH has a 2.8 cu ft firebox and produces that many BTUs easily with hardwood...and has long burn times producing the high BTU's...twelve hours easy. My personal experience last winter was significant improved efficiency with the PH over my previous stove, a Fireview, and a much warmer, more comfortable home. So I would expect the PH would give you greater efficiency than the NC 30, and provide you with more BTUs. I suspect much less heat is lost up the chimney with this stove.
HOWEVER, the PH is a LOT more expensive than the NC 30. The questions would be whether the difference in cost and increased high BTU burn times cause you significantly less use of alternative fuel, increase your living convenience, and don't have a significant negative effect on you financial situation. If money is no object and you'd like to try something different, I'd say go for a PH. You might like it more, find it more convenient, get a bit more heat , and find it somewhat more efficient.
Before getting a second stove and putting in a new chimney and going through the roof of a really energy efficient home, I personally would go the route of trying the PH, while keeping the NC 30 in storage. If you were really close to meeting all your needs with the NC 30, then the small additional heat you would likely get from the PH might do the trick. If not, you could always reinstall the NC 30 in the basement and install the PH upstairs at a later date....
The other significant factor is we don't know what your winter was like last year. Most of us had very mild winters. Could the NC 30 handle your home quite well on the really cold days? This coming winter, if more normal, might be a much better indicator to you of what you atually need to heat your home....
Believe it or not, that is up to you....I am 50 miles north of St. George. Elevation is 5800 ft.I am amused by this thread.
I'm close to believing WLFF Wife is trolling. If so, Kudos to you!
If not, you must be south of I-15, St. George or a lot lower. Your NC-30 is doing it's job, you need to look at another stove on your main floor. A pretty stove with a 6" flue requirement going straight up through the roof should fit the bill. I don't see a need for coring a concrete wall , unless it's really sandstone, in which case we need to see a floor plan to help.
Keep stacking wood.
edit- I burn Pine and Aspen , and.........yeah.
Do they sell them in the US?
I think you are putting too much value in the BTU ratings. They mean so little when it comes to actual burning. There are a few manufacturers that claim 100,000 BTUs from smaller fireboxes than the PH. Doesn't mean they heat better.I've looked at the NC 30 manual and specs....no expert here, but the firebox is 3.5 cu ft, and the co records in house testing resulting in 75000 BTU's per hour (doesn't give any details of the testing, or of burn times per load). The PH has a 2.8 cu ft firebox and produces that many BTUs easily with hardwood
Keep in mind, the OP is only using 2.25 cord of wood. Not exactly a lot of wood by anyone's measurements....and has long burn times producing the high BTU's...twelve hours easy. My personal experience last winter was significant improved efficiency with the PH over my previous stove, a Fireview, and a much warmer, more comfortable home. So I would expect the PH would give you greater efficiency than the NC 30, and provide you with more BTUs. I suspect much less heat is lost up the chimney with this stove.
Nothing wrong with the PH, but in this particular instance, wouldn't just moving up to the BK King make more sense?HOWEVER, the PH is a LOT more expensive than the NC 30. The questions would be whether the difference in cost and increased high BTU burn times cause you significantly less use of alternative fuel, increase your living convenience, and don't have a significant negative effect on you financial situation. If money is no object and you'd like to try something different, I'd say go for a PH. You might like it more, find it more convenient, get a bit more heat , and find it somewhat more efficient.
My opinion on this is that trying to heat 6,000+ sq ft with one stove is going to be tough. For more even heat a second heat source would seem to be the way to go.Before getting a second stove and putting in a new chimney and going through the roof of a really energy efficient home, I personally would go the route of trying the PH, while keeping the NC 30 in storage. If you were really close to meeting all your needs with the NC 30, then the small additional heat you would likely get from the PH might do the trick. If not, you could always reinstall the NC 30 in the basement and install the PH upstairs at a later date....
Now that location is narrowed down, a rough floor plan would be nice. Pictures of the upper levels? This would be for my benefit also, I have friends in your neighborhood who are looking into burning wood for heat also.Believe it or not, that is up to you....I am 50 miles north of St. George. Elevation is 5800 ft.
