woodsie8 said:Does a liner ever fail?
Jerry_NJ said:Hum, I think it is common practice to wrap or otherwise insulate the liner to help keep it hot when it is in an exterior chimney, as most are. If the chimney is internal to the house the insulation isn't needed, and that saves $$$. In any case, we need to keep the chimney hot even when the fire is low if we're to minimize creosote. I have never heard anything about putting vents in the top plate, sounds wrong to me.
stanleyjohn said:Jerry_NJ said:Hum, I think it is common practice to wrap or otherwise insulate the liner to help keep it hot when it is in an exterior chimney, as most are. If the chimney is internal to the house the insulation isn't needed, and that saves $$$. In any case, we need to keep the chimney hot even when the fire is low if we're to minimize creosote. I have never heard anything about putting vents in the top plate, sounds wrong to me.
I'm not to sure that a wrap around the liner is very common.When i went shopping for a wood stove i went to 3 places in my area and not one included a wrap in the estimate.It did not even come up in conversation.PS!they all knew i had a external chimney.
Jerry_NJ said:Well, not sure where this leaves me, but it seem that I may not need the expense of insulation. I have a 1985 built fireplace wall that is free standing and is outside the exterior frame wall of the house. The 11x11 tile liner has, of course, vented without the benefit of any liner many fires in the fireplace and in an old-fashioned insert that just dumped into the fireplace smoke chamber, no up pipe at all. The tile line is surrounded by a brick exterior and interior, that faces the inside of the house. As for clearance to combustibles, I'd say there is a minimum of 6" of brick. So, if the insulation doesn't improve the performance: creosote management and/or draft, why must I spend the money for an insulation wrap? One bid I have specifically quotes $450 for insulation, or about 10% of the total cost of equipment plus installation. Seems like a real savings to not get insulation.
I can say my experience with tho old insert, I used it for 15 years, it managed to put a lot of heat into the house without the benefit of even a liner, never mind any insulation other than the masonry materials.
Jerry_NJ said:Sean,
Thanks, that's helpful input.
It is unlikely I will live in this house for more than another 5 years, so pay back on the insulation isn't likely, but better efficiency is still a plus. This will not be a selling issue, or will it, given the price of oil an efficient insert may add at least the going cost of one in the selling price (faster sale at least). I have one price insulation for a 31' liner of $450, overall installation a separate item of $625. Another estimate is $346.25 for an insulation kit (must be right out of the "book" to include the 25 cents) and overall installation of $750. When the cost of the liner and connecting parts top and bottom are added one bid is: $2,000 and the other is $2025. They must be using the same play book with a different allocation of prices/costs. So the installation cost is not the determining factor, of course I don't have details on the materials other than flexible stainless steel liner (continuous or one piece), everything else is totally generic, e.g., Insulation, connector, collar plate, cap...
