Hearth and P. E. Super 27 install
Ubookz
37
British Columbia
Friends! It is done, waiting for a w.e.t.t. inspection(Canada). It was a job, putting in a new chimney and the learning curve. It is an ICC Excel chimney system-the thought I have is that the through ceiling coupler could have been a little wider (for my peace of mind) although it is all certified. Also tricky to keep everything plumb to maintain proper clearances. Plus I had to go through a rafter and floor joist which meant extra bracing. Also a 4' length turns out to be 46-1/2 when coupled; had to add 1' to maintain height.
The hearth was the easier part but anyone who has done it knows tile glue and grout is messy! I had a $60 tile saw, and that worked well. A cold air intake was installed that draws from the basement, on this stove a 4" hole (with rodent screen) needs to be located under the pedestal.
So waiting for the inspector before firing. The latest issue I have is with fire insurance; it seems my company does not like wood heat; they even sent me a letter previously encouraging me to switch away from a wood furnace! I understand the unknown is the ability of the stove operator!
Anyways I am now committed, :lol: with the wood stove community. Found 2 new sources of firewood, "Firemasters" make packs of campfire wood and ship all over; even to Alaska! they said; so all the culls and improper splits are discarded out back :cheese: which I can get for $10 a pick-up load, this is dry seasoned spruce, lodgepole pine-do not have to split or start my saw, just transport and stack.
  • Hearth and P. E. Super 27 install
Nice job. It looks sweet and ready to heat!
I would consider ducting the OAK to outdoors. Creating negative pressure in the basement can lead to cold air infiltration there which can result in cold floors and frozen pipes. If there is a furnace and/or gas hw heater down there, they may end up starving for air.
Congrats!!! Looks Great!!!
Nice job. As for insurance, I have state farm and they have no issues with wood heat in Ontario.
Big honkin steel stoves. Love'em.
Very nice job. Rick
Nice job !!! You are going to love that stove :)
Very nice.
Sweet looking install. I am gonna back up BG on the OAK poking out to fresh air. It will give you your best performance when installed as advertised.
Thanks all for the positive replies, :) I can feel a steady flow of air from the basement; the oak air inlet is set up so I can add an outside air to it, will monitor this as i really don't know how much air the stove will draw. Also the pedestal is not absolutely air-tight, the slot where the draft control is located.
The next hurdle is the insurance, I can only hope it won't go up to much! I have heard some stories of not being able to get insurance?
How many here decide to carry no insurance because it is not affordable? There are many brokers in BC and I may have to contact them.
Still getting winter fuel as available. :roll:
My insurance company had a couple of requirements. Once those were met, it was inspected by my carrier (with pics) and it had no adverse affect on my rate. Just say'in that there are companies out there that will carry your insurance, even with a stove.
Nice install and nice stove im sure you will love it! I do not have a OAK as i have heard so many pros and cons about it, but it all depends on the particular situation-climate im sure... each one is different and unique. As far as insurance, mine included a inspection and a tape measure by the company. No big deal and they where happy. If someone is going to cancel your policy because of a wood stove than i would be for sure shopping around. Like any other form of heat (or anything else in a household for that matter) if properly installed, run, and maintained they are just as safe as any other source of heat. In the end its always up to the homeowner on how that outcome is, and how safe any heating device is. Good luck and enjoy! It really is a wonderful stove.
If you are noticing that with windows and doors closed in the basement, there are either significant leaks there or it is pulling through a vent. Which vent I am not sure. Could be a dryer, furnace, etc.. The same thing will happen in winter when burning, but much more so.
This is an old house with only half basement, the remainder is a crawl space; i will spend some time under there to check for air leaks. Thanks for the help. The oak is also a possibility, will look at the possible inlet location. The insurance will be resolved I hope :roll: waiting for the wett inspection. Have about 3 cords of wood now-most is dry-from Firemasters the campfire wood sellers :)
Ubookz said:
. . . The next hurdle is the insurance, I can only hope it won't go up to much! I have heard some stories of not being able to get insurance?
Insurance carriers vary widely . . . some will not insure you with a woodstove, others will increase the rates, some will require you to fill out paperwork, have the stove professionally installed, inspected by a fire inspector, inspected by their agent, etc. It really depends on the insurance company.
In my own case with Travelers I saw no increase in the cost of my insurance, but I did have to have the stove professionally installed, I filled out some paperwork and had it inspected by the fire chief and I had to send in the paperwork.
I would not do without insurance on the house . . . but that could just be me personally . . . having seen too many people lose their homes and possessions to fire.
Update: I had my 1st fire in the super 27 today, the w.e.t.t. safety inspection passed a week ago but I can't wait until fall! so it is a little cozy & warm at my place now :lol: have spent the last few weeks getting firewood-now have 7.4 cords. Lately I have been lusting after a new chainsaw-although my 024 gets the job done. It is getting warmer in here! but I am happy with seeing the burning.
Congratulations. Burn your driest wood first and you will be a happy camper.
Congrats your hearth looks awesome and stove burns awesome!! I have a new T-5 which is your stove with cast iron around it and expect it look as good as yours does when burning :) The stove install is being inspected tomorrow and I can burn after that..
Good Luck!
Ray
Thanks for the comments! lit the stove again this morning, but will let it burn out, I was expecting some crackling noises but burns quiet, fun to enjoy the process and watch the flame. :lol: It gives good heat with a small amount of wood.
Looks awesome! Wait until you have it loaded up this winter and the secondaries are blazing it's quite the light show.
It's a shame to have such a beautiful stove and nice looking hearth sitting right smack in the middle of that ugly carpet ;)
