Hello forum,
Great site! I've enjoyed using all of the information here to begin installing an alternative to baseboard heat. So, I've torn apart an older Homestead I just bought ($500 +450 shipping) and have several questions:
#1: One of the rear firebricks is cracked in half and there is a retrofit "rear brick kit" (95-83700) to replace it. Sounds like it is 2 4x9" standard bricks and an 8" channel steel spacer (5957-000). Rather than waste $43 (plus it's on backorder), I'd rather waste my time looking for the width of the steel channel and do it myself. Any folks out there with a newer Homestead willing to take a look under their hood? The other thought is to cement the two original pieces back together and worry about it next summer.
#2: All of the steel splines have been wrapped in flat tape and then embedded in cement. The tech docs I've seen on replacing soapstone panels don't mention this tape. Is this an obsolete assembly method or should I put it back the way I found it? Is it to account for steel expanding and contracting at a significantly different rate than the stove cement? There was also a gasket embedded in cement between the top and sides...
#3: Any experience cold welding cast iron? I've got a 3" small crack on the rear panel. I've put a hole at the end of it to stop it from growing and am planning on using Blue Magic Quiksteel Xtreme to close it up after grooving and cleaning. Anyone else think this is a good idea?
Thanks!
Thanks!
