Heat cure without lighting a fire?
Aksoprano
2
Alabama
Just painted the inside of my wood burning fireplace with rust oleum high heat. We rent this out and want to put something large and decorative in it to deter renters from using it, but we aren’t ruling out ever using it again someday, so instead of normal paint, we went with high heat. It has been 24 hours and the house still reeks, despite windows and doors being open. I was reading about heat cure at 450 degrees, but as I don’t want to light it and make a mess, is there an alternative way to get that kind of heat? Will the smell dissipate if we don’t cure it? Thanks!
Ashful
18,622
Philadelphia
The reality is that stove is going to stink each time it hits a new high temperature. 700F is normal and 900F isn't uncommon for stove top temperature on an iron or single wall steel stove. At 450F, you're just starting to pre-heat the thing.
gthomas785
865
Central MA
I don't know why you would need to paint the inside of a masonry fireplace but the smell should go away after a few more days. In the meantime did you try opening the flue to draft the fumes out that way?
brenndatomu
7,983
NE Ohio
xman23
2,548
Lackawaxen PA
Get an electric heater in there. It just needs to dry / cure.
Aksoprano
2
Alabama
Thanks for the insight. We painted it thinking it would look less used and therefore less likely to BE used. And it turned out great! Good thinking with the flue. Will definitely try that first and may bring in a heater if that doesn’t do the trick.
