We had a Heat n Glo I35F installed in Dec 2015. The fan was making a high pitched squeal which was swapped out under warranty. Then, the replacement fan started making a different noise which was attributed to a wire that had somehow come into contact causing a vibration type noise. The fan issue was fixed under warranty.
Flame Height Issue:
While the tech was out - I asked him about the height of the flame on the unit which never seemed to fluctuate much (if at all). On the remote there are 5 positions from low to high; to me, even though the remote 'beeped' when adjusted by the remote the flame did not appear to me to get any higher or lower. Was I just expecting more of difference between low and high or was something wrong? The tech confirmed that the flame was 'stuck' on "medium" and that there should be an obvious visual difference between low and high (there is not).
The tech then replaced the valve, the module, and even tried a new remote control. He checked the pressure of the gas, we are at 2.7 which he said was consistent with a 'medium' height and that the flame height seemed to be stuck on medium - visually going no higher or no lower when adjusted using the remote. He did the diagnostics by resetting the solenoid, he called Hearth and Home Technology and spoke to a rep and they could not offer anything else. He is not sure what else to do except try another new valve in case the replacement valve was somehow bad. Does anyone have any advice for this?
Warmth/Temperature
Since we've had the unit installed, we've enjoyed the ambience and sitting on the hearth in front of it becomes hot after a couple of minutes. However, my parents home which is a very large great room with 20 foot ceilings has a heat n glo unit installed (their fireplace is 10+ years old) and in their home when the fireplace is on and the fan on, the ENTIRE ROOM gets noticeably warm. In fact, they usually have to turn the fan off because it gets uncomfortably warm after a while if you leave the fan on. In my home (which is roughly 20x20 with standard ceiling height) which does open up into the kitchen it never seems to get 'uncomfortably' warm. We leave the fan on medium almost all the time and it never gets more than 72 degrees or so in that room. In my research prior to purchasing, I learned that buying a gas insert like this was 'like putting a 2nd furnace in your living room'. Is that really true? If so, shouldn't it be getting 'uncomfortably warm' in our family room after a few hours? Or am I expecting too much? We purposely keep the house thermostat heat at 63 and only heat the family room where we spend most of our time using the fireplace. This was another reason for wanting to purchase the heat n glo gas insert. I know it may be difficult to comment without seeing the layout of the room but should we expect to it to be warmer? Could the fact that our flame height (see above issue) never gets 'high' be contributing?
I'd appreciate any input or advice that may help me temper my expectations on either of these.
Flame Height Issue:
Warmth/Temperature
