Heatilator WS22 Tempature
Brandon3r
16
Indiana
Can anyone who has a Heatilator stove tell me how hot they run their stove top? I have a stovetop thermometer and it says at 600 degrees the stove is to hot and in the over fire range. So how hot is to hot? I don't even have to have the fire box full and with the air controll closed it still runs at 600 degrees.
You are good right up to 700*. Likely fine even a little north of that. If you can ride at 600* with air all the way down, you are burning great.
So what your saying is my thermometer is a tad on the conservative side and I can open it up a little more and still be fine?
I guess what I am saying is 600 is plenty within the safe range. Rolling at 600* with air all the way down is primo burning; efficient and hot, just what you want.
If you want to take it a bit higher, just let the temp come up a bit more before cutting the air back. Just keep an eye on it until you are comfortable because they can ramp up quick.
Can only ride at 600 for thirty minutes or so then falls off pretty quick.
Somewhat normal. Remember, if you are using a blower (???), that will contribute to the stove cooling a bit. The higher the blower fan is turned up, the more it will affect stove temps.
Your peaks should be in the 725-600 range, your 'cruise' burn throughout the majority of your burn duration should characteristically be 550-400. Then as the burn is in its final couple hours, typically it will fall to 375-200.
