heating
Pellet stove on the last 2 days . This morning house cool enough to put the propane on .
Tuesday, they are forecasting a high of 31::C with a humidex . Maybe I will think about
putting the stove to bed for the summer. Just maybe!!
My basement only gets to 18C usually so I run it starting at about supper time then shut it off at bed time. On room mode it does not run too long and then cycles. I have it set to 23C. I will probably run it like that all summer. Do I need to worry about rust? I read that most guys clean it and block the vent, then put some damp rid? in it. Some guys even spray WD40 in there.
mine has been running for 3 hrs now. _g morning and evening daily
I don't need to run mine until later in the day, but it appears my basement stays pretty cool. The really hot weather is not here yet.
I will have the upstairs in cool mode so the basement probably won't change too much. Can you comment:
"I will probably run it like that all summer. Do I need to worry about rust? I read that most guys clean it and block the vent, then put some damp rid? in it. Some guys even spray WD40 in there."
If I have a fire for 4 hours everyday will I dry it out? I have a dehumidfier running but not in the main room. Right now the humidity is between 50 and 55 near the stove.
If you run it every day, or even once a week, you shouldn't have issues with rust. When I shut my stoves down for the season, clean, spray graphite on the exhaust fan and the retainer assembly for the exhaust fan plate, block off the exhaust and OAK, and call it a season. Some years I put in wadded up newspaper, some years I don't.
I never use damp rid - I hear it attracts moisture and that would be silly as humid as it gets - I'd be dumping that thing all the time (or not, because I would forget). There were a couple of years I sprayed the P61a ashpan area with fogging oil (and heat the stove up as per directions), but I'm not sure if it really did anything. I do have a little rust inside the P61a, but it doesn't seem to spread. I've never sprayed the P43 with anything (except the graphite), and it has no rust inside.
It was in the 80's here today and set at 71 it fired up twice.
I hear ya. It seems strange though having my upstairs at 22C (using 2 heat pumps on cool), then going down to the basement and it's 18C.
I'm OK with running it though. I hardly use any pellets. It does not stay on for very long. I guess at some point in July and August I will feel really weird about running it. Last summer was super hot, even in June. This year is cooler/wetter so I'm not sure, as I only got it in Feb.
I was getting all geared up for my first big cleaning including the vent pipe and now I appear to be doing nothing.
I am hoping the heating season is finally over
Last week, the wood furnace was on . One day ran the
propane and the pellet stove on and off
To day 31::C with a humidity of 35, not so warm the rest of the week
But still into the 20s with a humidex, so maybe just maybe next week
I do the cleaning of both the wood furnace and the chimney, and the pellet stove
Then, come September 4 cord of hardwood in the basement and the first of 3
Skids of pellets will show up . The never-ending battle of keeping warm
Ever One have a Great Summer
Meanwhile my pellet stove already has a layer of dust on it from not being used ;lol
I do longingly look at that space the stove takes up over the summer months and think about how awesome it would be to swap that out with a pellet pizza oven.
We appear to still be in heating season here with cool damp weather. Going down to 7C overnight and they issued a frost warning.
Still using mine every night to warm up the basement. I have been trying thermostat mode with the igniter switched off (once it's running). That makes it go to a low flame, although even that is too much after a couple of hours so I shut it off. I have been getting quite a bit of work done outside this spring. Last year was really hot around this time of year. I don't really miss it for now. There's still lots more heat to come.
Reactions: Ssyko
It was 4 this morning at 6am, turned the propane on to take he chill out .
Will be a cool day at 18 but warming up again on Sunday
We used our pellet stove last night, and most nights lately to be honest. It's partly the weather, which is not truly warm, but also the body's conditioning to many winters of t-shirt weather in the home thanks to our P-68. I feel like it's caused me to lose my tolerance for a slightly cool house.
I still use mine everyday because it's in the basement and that is where my big TV is. It stays about 18 or 19C. I tried my electric heater 2000W but that seemed like a waste. I got used to a warm basement over winter. I have the P43 going as low as I can (after a hot start) and after 3 hours it says 25C above the stove and I shut it off for the night. Funny the 25C just feels nice down there, but upstairs I can only stand about 22C max (I have 2 mini splits upstairs)
Monday I deep cleaned the P43 and put it up for the season. Will probably turn on the mini split today as it is, and will stay humid and supposed to get very warm. 75* on the main floor right now feels cooler than the 68* that the outside temp is.
[Hearth.com] heating
Ahhhh well…might as well post this…heavy rainfall and heavy snowfall warning here in Kananaskis Alberta Canada…1c/34f so the stove is running again, heavy wet snow overnight and 84mm 3.5 inches of rain so far in the past 24hrs
I heard on the news Calgary could get 100mm of rain and flood again. Here we are chilly again after a mini heat wave
Yeah and because of where I live the upslope is hitting us hard, 94mm/3.7in now
I don't usually do my big annual clean and service until either July or August. I'm in NY and there are occasional cold nights in May and June where we end up starting the stove for a couple hours in the evening, This spring has been particularly wet and cool, and we had some night temps in the 40's as late as a week or so ago. The stove took out the dampness and made it cozy on those evenings. I almost never let it run over night though past mid May.
This will be my first summer with the stove. I know this year is cooler and wetter than last year though. Yesterday was hot and humid here. My basement only went up to 20C and had had to hold myself back from turning it on at night to watch TV. I am running it tonight and tomorrow for sure. I have been using room mode, feed 1.5, and then turning the igniter off once it's going. That's as low as it will go.
I love your trim kit!!! I had to order mine barebone as it was more expensive than other types.
Check this out- weird weather
Environment Canada has issued a heat warning for a “dangerously hot and humid” wave coming to Toronto, as temperatures could potentially reach their highest in two years.
The national weather agency predicts starting Sunday, temperatures could reach 31 to 36 C and little relief overnight with lows of 21 to 25 C. The heat wave is expected to intensify on Monday, before a cold front arrives late Tuesday or Wednesday morning, officials suggest.
“If it gets to 35 on Monday, let me tell you, there has not been a warmer day in the last two years in Toronto and we’re not even to the dog days of summer yet,” said David Phillips of Environment Canada.
Stove is on…took a drive 20min south of me, 7400ft
  • [Hearth.com] heating
  • IMG_4598.mov
    15.4 MB
Heat wave here also, Real Feel (humidex) 40::C
To hot for this northern boy
The only time I like weather like that is if I'm on the lake or at the beach. I grew up in a second floor bedroom with no AC
in the house. I have no idea how if I could do that now. Even sleeping in tent would be too hot. Might go for a walk on the beach
tomorrow if the wind is down. Going to feel 37F
Mid 90's with high humidity last week here. Mid 80's with high humidity now and thru mid next week. Heat pump running in a/c mode, 76 degrees with humidity @ 50%. Come on fall!
