Looks great - happy heating! I love the full-view door. As an aside, my daughters and wife are coming up to your neck of the woods to do some antiquing this weekend. They are thinking it will be prime-time for fall foliage up there. True?
![[Hearth.com] Help deciding on insert- Osburn 2000 or 2400? [Hearth.com] Help deciding on insert- Osburn 2000 or 2400?](https://www.hearth.com/talk/data/attachments/141/141036-df74b26b81b172bc0343235ca93afafe.jpg?hash=gq92GEpFOD)
![[Hearth.com] Help deciding on insert- Osburn 2000 or 2400? [Hearth.com] Help deciding on insert- Osburn 2000 or 2400?](https://www.hearth.com/talk/data/attachments/141/141041-d02744b449174e35fa284b3533646027.jpg?hash=kceiIoMJ-0)
No worries - they had a great visit and said it was beautiful. Looks like the computer down time was put to good use - looks great!Andy, sorry for delay.
The block off plate was so close to the top of the stove (5") made it a LOT of work to connect the liner to the.. Worth it now with the full surround being rocked and insulated but a few choice words getting it all together. I think this will make a difference in heat retention and ultimately performance like you all said. PITA for sure! Left stove sticking out max for most heat transfer possible - heat is the priority over beauty. I did compromise with the boss and got the brushed nickel face to give it a prettier dress.... Happy wife worth $180!
About 2" of clearance in back on L and R. Plenty in front. Rear top about 1" clear and about 5" on bottom. Blower not too bad on noise after some "tuning" to keep the covers from vibrating.
PaulCT - Its pretty flush (about 3/4" delta). Cant really say since only did the lower temp, shorter duration break-ins (about 450 for 1-2 hrs) so far and they didnt raise temps on anything really. I am waiting for the back-ordered heat shield before I really get going to be safe. This week is supposed to be back in the 70's daytime so wont need much heat. I burned an open fireplace for 15 years here 5-6x a week and the floor has more burns than Freddy Krueger... If the house (and the dogs) didnt go up from all those, Im not overly worried... Planning to get the ugly black metal floor pad ($80) my local guy has incase someone wants to "stop by". Ins had no issues with the insert. No upcharge, no inspection, no further discussion...I noticed your hearth is level with the floor. I just installed my 2000 last week, and have the same setup. How hot did your floor get? The manual says with a level heath, you need 29" of R2.0 protection in front. I confirmed this with Osburn (they double checked their test reports). Mine wouldn't pass inspection without a pad extending out the 29"
Right! Wish they used screws or locking pins to keep everything tight.. Loose sheet metal held in place with drop-in eyelets and "clips", on a squirrel cage blower, really?!Congrat! I have to laugh because as much as I love my 2000, I do find occasional "Vibration Tuning" is necessary haha.
Thanks begreen! Keep you posted as we get going over next few monthsWell done and nice job. Thanks for the visuals. That's a nice install.
I tried the fan on floor opposite end thing on the 2nd burn and it seemed to work pretty well. The air turbidity really helped to balance out hot/cold spots. I was also pleased to see the temp in the far end (90 degrees down hallway) go up 4 degrees without any extra effort. It hasn't been cold yet, but was encouraging. I think with a fan at that end also we might just do alright. Thanks for all the tips!A few hints for keeping the house temps a little closer to even:
-We keep electric space heaters in the bedrooms so we can close doors and still have heat.
-If it gets too hot you can turn the fan off. The insert will still give off heat, but not as much.
-No matter the size of the firebox, if you want to bring house temps up and it's mild outside, a small, quick, hot fire will get the job done nicely.
-A small fan on the floor in the farthest part of the house blowing on low towards the stove room will help create a convection loop and bring the heat closer to the desired space.
I know some of that is generic and probably repetitive, I just figured this May be helpful based on your concerns of cooking the living room.
OK, so I know wasnt real cold last night, and a newbie, but...
Was around 45 out, raining and 20-30 MPH winds with this Nor'easter thing going on. Started a small fire around 7 with only the balance of the pallet wood and a few 2-3" rounds. Maybe 1/2 box full loosley? Went to bed around 11 with 1/2 burnt and about 1/2 deep char/coal'ish. Stove temp about 500 blower on 30%. Main house up to 78 and far end up from 67 to 72 (with 2 fans doing the convection loop thing). Woke up this AM and fan on stove was still running! Not a speck of coals I could see, but enough heat in stove to keep fan running. House at 72 still. Outside low 40's and still raining. I suspect the insulating/Durarock set-up makes a huge difference in keeping the stove heat in. Wish I had a before and after comparison, but this was impressive to me?
Hello
I am new and been lurking here for a bit. I am also going to look at this set up.
Have you figured the fan thing out?
How do you think bigger would have been?
Thanks
