Brand new here, so please pardon my ignorance.
Recently had a new Blaze King Chinook 30 installed at my home with a fresh air intake and blower fan. Since the initial installation I have struggled with smoke and smell issues and am hoping for a little insight from experienced owners. For the record, I have contacted the installer and Blaze King. I'll try to keep it reasonable length.
First issue - Inability to run the stove on any setting lower than medium on the thermostat without getting a loot of smoke smell and sometimes actual smoke inside the home. Enough to trip smoke alarms. According to installer and BK support I shouldn't really even be smelling smoke except maybe a tad when reloading. Determined initial chimney (single story straight out the ceiling with no bends) was to short at 14' and not creating enough draft. Installer came out and added a 3 foot extension and now we are at 17' from top of stove to cap and so far draft is better. Smoke smell is probably 90% better, but still there. No spillage to speak of when opening to reload. I still notice smoke or creosote smell around the top of the stove when trying to burn on lower settings even when the needle is in active zone.
Question - Is it normal to get smoke smell when using a BK stove on most settings? I know the obvious answer should be duh, you are burning wood and therefore it is logical to expect smell related to it. However, both BK and installer pretty much said that with proper draft this thing is so efficient, you shouldn't notice any smoke smells at all. What say the experienced folks? FYI I am in the Northwest and burning Alder and Maple with moisture content around 15%.
Second issue- Smoke smell any time I run the blower / fan to circulate the heat. Is this normal? Both BK and installer say no, but we have taken heat shields off to inspect welds, looked over the whole stove and can't see anything obvious. I notice the smell coming right out of the top of the stove vents and I also smell it here when the fan is off and right around the flue where it connects into the chimney on top of the stove. Nothing is obviously wrong by sight, but it is very noticeable anywhere in the general area of the living room. Not to the point of needing to go outside, but just enough to make me question if I should be smelling it at all.
Sorry for the ramble, but I really like this stove aesthetically and it puts out great heat. I just don't like the smoke smell and want to make sure nothing is out of the ordinary here. I appreciate your time to read this and respond if you have any ideas.
