Hope everyone has a wonderful and warm Thanksgiving!
Hello I have a jotul c550 rockland and I was burning it tonight and a piece of pine got in there by accident and when it was burning it splattered some pitch/sap on the glass. anyone have any suggestions how to get this stuff off!!
Oh no, the dreaded pine in the woodstove . . . a sure sign of the Apocalypse!
No worries with pine . . . or with the sap on the glass . . . as SandW said just get a nice, hot fire in there next time and it will burn it right off . . . at least it does every time I have any sap-spitting softwood burning in my woodstove.
If it actually splattered sap on the window, I'd question whether or not the wood is well seasoned. I burn more Pine than any other type of fuel, and I've never had that happen. Sure, my windows get dirty over time, but just the typical gray/brown/black discoloration. Every couple of weeks or so, it cleans off quite easily with Windex & a paper towel. I would never use a razor blade for fear of scratching the ceramic. Rick
You're more likely to scratch it with a cloth contaminated with sand than with a razor blade. Razors are how most ceramic cook top manufacturers suggest getting burnt food off. Steel is a lot softer than glass.
Thanks for the help everyone. I ended up just getting a nice hot fire and it burnt most of it off. The stuff that didn't come off with the fire, I was able to get it off by dipping my finger in a little warm water and then into some pure white ash from my fire box and just rub it with my finger. good as new!! Did I mention I love this stove!
Even better than using your finger is to use some damp newspaper and dip that in the ash . . . I clean my glass weekly this way . . . no need for Windex or fancy woodstove glass cleaners.
Incidentally, as you may or may not know, typically you'll get that black if either you're not burning hot enough, you're burning unseasoned wood (which is not allowing the firebox temp to get hot enough) or if you have a split that it touching the glass. In the case of softwoods, you may get some sap splatter . . . but as noted . . . no big deal. Next time you burn hot enough most of the black will burn off.
