I could use some help picking a stove. I'm going blind from all the info I've been reading and the stoves I've been looking at.
House is 1772 sqft total. Ranch house in Northern NJ. 8 foot ceilings. stove will be in the corner of a 15 X 17 room that is the center of the house. The end of one wall that the stove is on has a opening to a hallway with 3 bedrooms off it. The end of the other wall that the stove is on has an opening wide to the kitchen and dining room (all open floorplan appx 12 X 25)
I'm coming from an old insert in a zc fireplace that I took and and am starting from scratch.
I usually start the fire from 6-7pm each night and tend til I got to bed about 11 pm and then let burn out. The old stove would be done heating in about 3 hours. I had a vent in the ceiling of the stove room to some insulated duct pulling air to each bedroom. It would do ok maintain temps in the bedroom, but would not heat them up. so I'm still undecided if it worked well or not.
I also burn 24 X 7 when home on the weekends. I have not burned while out of the house intentionally. If a fire would be running, I would go out to dinner, but I would not start a fire and then leave for work. If I knew I would not be home, I would not burn the stove.
Anyway, been looking at stoves. This will be a corner installation
I'd like to get a stove that tucks into the corner as much as possible, but it's not the primary factor, nor is price the primary factor. Getting a quality and efficient stove is the primary factors. Also the size and openness of the viewing window. The wife wants to see the flames. I'm also not 100% sure I like a top loading stove, but I'v enever owned one to make an educated guess.
I can get away with less side clearance in the Hearthstone heritage with an optional lock that locks the side door closed.
Right now at the top are
Hearthstone Heritage. Lopi Endeavor and jotul f500. I would go with the hearthstone because we really like the way it looks, the thing that's stopping me is that the soapstone stove takes longer to heat up than steel or cast iron. I'm not sure if that's good or bad. I know the heat will last longer. but my initial thoughts is if I were starting from scratch each night or a weekend morning, it would be 3 hours before the stove was up to temps.
We have looked at avalon arbor & ranier, dutchwest medium, harmon oakwood, hearthstone heritage and phoenix, jotul f500, vermont castings endavor, quadrafire 4300
Can anyone lend any insight as to what they like/dislike or any other suggestions.
Thanks for the help,
Nick
Nick
all burning and supporting Englanders. It is the best American buy.
