I live in Sitka, on the outer coast in southeast Alaska, and we tend to use our stove for 8 or 9 months each year. Our fall is wet and windy so the dryness of a fire is nice as well as the heat. Our winters are long and mild - usually upper 30s and lower 40s for weeks at a time. We have occasional colder spells in the teens, but they don't usually last more than a week, once or twice a winter. The coolness and wetness of early spring can linger into May before we get warm enough to not want fires. During particularly cold and rainy summers, we've had fires into June and even July. We usually make a fire in the late afternoon and let it go out overnight; we rarely need a fire to be going for days at a time.
We just moved into a house that has a rusted out old stove that needs replacement. We spent the last 5 years in a house that had an older non-catalytic stove; I believe it was a medium size Ashley, something like an older version of this.
My biggest issue in choosing a new stove is the challenge of keeping a well-seasoned firewood supply here. We have a small yard, so we can't keep much more than one year's worth of firewood on hand. We can keep a little more than a year's worth, but definitely not two seasons worth of wood. I manage this as best I can by dividing my woodshed into many narrow sections, so as soon as a section is empty I can refill it with fresh wood and maximize seasoning time.
I've used a moisture meter for about three years now, so I have a pretty good sense of how our wood dries. I have a decent woodshed, open on all sides and covered on top, with good airflow. The main problem is sometimes we have "summers" with just a handful of dry days. Almost everything I cut is alder or hemlock, and it consistently reads about 38% MC when it's freshly cut and split. By the time I need to burn it, it's usually 25-28%. One year we had almost no rain all summer and I left my wood in uncovered stacks in bright sun with good airflow before putting it in the shed, and that wood dried to 20-24% over a 12-18 month span. I split my wood as small as it can reasonably be split to maximize drying.
I've had no problems with this level of moisture. Our stove was in a one-story section of the house, with a short straight chimney that was really easy to check and clean. I ended up cleaning it twice a year, and I never saw significant buildup of anything in the stack. Our new house (built in 1940, so new to us) has a similar setup, in fact the chimney is even easier to access here.
I can have a stove barged in if I need to, but that's probably significantly more expensive than having a store include it in their larger order. The local stores work with Blaze King and Ashley. I started getting interested in a couple Blaze King models, but then read up on how to use a catalytic stove. I'm really hesitant to buy a catalytic stove knowing the moisture content of the wood we burn. It's just not realistic to try to maintain a steady supply of <20% MC wood.
I'm leaning towards ordering a medium size Ashley just like we've been using. Is that a reasonable idea given the constraints of seasoning here?
