Okay. Ihave been really happy with the heat output of this stove. It's beautiful and heating great.
Just one problem. I keep getting slightly stingy eyes and throat and can smell a odd smoky smell much of the time we are burning, which is most of the time. I am keeping my birds in a separate room with an electric heater, unless the stove isn't smelling, and then they are out inthe living room.
I really thought that I could use a HEPA air filter to filter out the smoke smell out of the air, but it isn't working. I open a window, but I don't know if this aids the draft in pulling out all smoke traces or not.
My husband thinks this is all in my head, but he's the kind of guy who can stand around in the pits, breathing exhaust from race cars burning methanol and think it's just fine. If I do that, my eyes burn and I run away since I cannot breathe at all. He also reloads the fire with this method, turn off the air intake lever, slowly open the side door so that the smoke from the stove keeps going in and up the chimney, put one split in on top of the coals, then gently close the door, and turn the air up a teeny bit, for a minute and then back down to nearly zero, while the new split slowly, slowlyheats up,then smokes and then finally starts to barely burn. Meanwhile, it really gives off a smelly smell.
Well, I have done some checking tonight, and it seems from the research, that we may have an inadequate chimney, or it's not tall enough to pull enough of a draft or our wood isnt' dry enough. I will pick up some grocery store wood tomorrow to see if it burns differently.
My question is this: Is there anything at all I can do to reduce the smoke smell or helpthe chimney draft better? We did do the install ourselves, and we thought everything was to spec. I need to measure the chimney height to make sure it's to spec. If it's not, and this is my guess, how hard is it to add a section to the top of the chimney?????
BTW, Ichecked all the gaskets but the ash pan door, and they are tight. The chimney section that connects to the top of the stove didn't have a gasket, should it?
HELP!~
HELP!~
