The instructions say "NOTE: When a suspended ceiling is encountered a Cathedral Ceiling
Support Box is to be installed. Secure the Cathedral Ceiling Support Box to the floor/ceiling joist framed on all 4 sides. The box must extend a minimum of 1" into the room below the suspended ceiling. Chimney
Length is to protrude a minimum of 3" below support. Trim angles must be installed.
I'm making a suspended ceiling on the back wall and behind a decorative open beam. The bottom of the beam is 2" below the suspended ceiling. The bottom of the dropped ceiling is 56" below the 12/12 roof peak.
So I envision the 17.5" tall box extending 1" below the finished ceiling, then the pipe protruding some distance (3"?) below the beam. Am I on track here?
The Supervent install instruction is not clear that an attic insulation shield will fit/should be used with the cathedral box. It sort of implies it, but never says it specifically. I have the space and then some to get it on there. I don't want to order the parts if it's not going to fit / not to specs. Duratech has the same setup as I'm describing in their literature, but their pipe is pricey, so I'm trying to find another option.
Pic should clarify where I'm trying to go with this. I'm offsetting from center to avoid the peak. There is an attic space above the finished sheet rock. I'm not through framing yet, I stuck the 2x6 frame up there to decide if it will be doable.
I know it looks like crap now, Got paneling temped on to keep the some of the nasties out of the house until I figure this out. The plan is to re-insulate and drywall the whole back wall.
Opinion? Idea? I have a call in to Supervent tech but haven't heard back. I'm getting antsy...
![[Hearth.com] Help with Supervent install [Hearth.com] Help with Supervent install](https://www.hearth.com/talk/data/attachments/157/157661-0440206af1bb0ba08f6d4ee38e6bafb5.jpg)
