The door on this Papa Bear I just bought is a little sloppy. I miked the pins and they are both about .004" under 3/8" (0.375) where they ride in the hinge plates. The bottom hinge plate hole is about 0.010" over at 0.385. The top hinge plate is right on the money at 0.375.
So I plan to make my own hinge pins from bolts but I would like to address the bottom hinge plate. What is the best way to fix this? I thought about running a light weld bead in the hole and grinding it out to spec. then grind with a Dremel tool. A drill won't fit, the hole is too close to the stove body.
Any suggestions?
Any suggestions?
