Ok.. I've been amazed this year with how little smoke my Fireview has put out. I've never really seen any from the pipe and figured it must be one lean mean clean machine. For whatever silly reason I decided to take a look today when it was 11* outside to see what it looked like during a re-load. Now, mind you this may well have been an unusual re-load but wow! Talk about some major smoke pouring out of the chimney! It could well be that the cold weather was making the steam exaggerate things quite a bit, but I couldn't believe the volume of smoke spilling out of there. I came back into the house and engaged the cat, then took another look - within 30 seconds or so it was down to just a small bit of what I assume to be steam flowing out and dissipating a couple feet from the cap.
Now what made this reload a bit unusual is that it was a very packed stove that was quite hot to begin with. I had loaded and burned hot already once (first load) and was loading before heading to work so I put the largest pieces I could and filled in as much as possible. The load was roaring before I could finish filling the box. I wanted to wait 10 minutes before engaging the cat so I had turned air down to less than 2, maybe 1.5 range so perhaps that was generating the excess smoke. Once I engaged the cat it was glowing like mad and the temps went up very fast too...
So - I plan to keep an eye on the smoke when I reload. I don't want to me smoking out the neighborhood even for 10 minutes on reloads. Anyone have any general suggestions on how to minimize smoke during this time?
...its going to have some surface moisure on it and should smoke a lille bit. (Seems like when I reload, I get about 5 minutes of smokier stuff coming out my chimney, then its basically a clean burn)
