In my place, on the first floor or the basement, if the flue gets totally cold there is a downdraft. I might get a bit of a whiff from the basement pellet boiler, but so far so good. I also have to crack a window on the first floor and light a little newspaper for the wood insert if things get totally cold. Does your stove get totally cold? Did it work okay other times from a cold start (and downdraft-can you feel the draft with your hand?)?
Blaming it on the downdraft may be premature, no?
On a side note, my boiler has a little water reservoir that dumps water in the auger tube if things get hot in there.
How many feet in total is your vent run. And have you done the conversion propertys on this run.
