How hot is the temperature of your pellet stove in this weather?
Bontchimuz
17
Rye, NH
Ive been running my Harman P68 on feed limit 4, temp probe at 80-85 and fan on middle setting and my stove seems to be around 700-900 (in the red zone on the little circular temp disc i put on the side of it). Should I be worried its running in the red zone? I assume these stoves are made for this.
Ever since I added an OAK it has been running super amazing...maybe "too good" lol
Either way, I love this beast.
Turn the fan all the way up to get the max heat out of the stove. Are you in room temp or stove mode?
Sent from my SM-G930V using Tapatalk
Reactions: bags
When I first read this yesterday I thought that temp was way too hot. I took the side temperature of my P61a last night and it was at 470+*. The stove wasn't even working hard at a feed rate of 3, temp set at 75. fan rate of high and I'm using middling pellets, so I guess your temps don't seem unreasonable.
Just went down and checked with it just above idling and the side temp is 375.
As Tony said. Fan all the way up and get that heat out and off of the stove. Your temps will also likely drop down into the good area. If it is still running that hot dial it down. Is it cooking you out? Maybe not because a decent amount of heat is not getting used inside the house and going out the exhaust.
On my P68 if it is super cold (single digits) I can get all the heat I need with the fan turned all the way up, feed rate 3, and room temp at 75*
