How many of you actually use the factory LOW setting
Itslay90
720
Upstate,NY
How many of you actually use the factory LOW setting on your newer, modern wood-burning stoves? Do you regularly burn on LOW, or do you prefer keeping the air control a little more open?
  • [Hearth.com] How many of you actually use the factory LOW setting
On my tube stove it was almost always on low. And with your history of over firing yours should be as well
Reactions: Itslay90
I rarely run as low as it can. I run it as low or high as is needed to be comfy.
But that's because my factory low is so low that if my home only needs that little energy to stay warm, it means that outside is not very cold and then I instead use my mini split to heat.
I've tested it though, and got 36-37 hrs on one load of red oak running at the low limit.
Reactions: Itslay90
Sounds good
This question is specific to the installation. A person with a 12' flue system is going to have a different answer than one with a flue that's twice as tall. It's also specific to the stove type and brand, the fuel being burned, and the size of the wood load.
bholler's response is correct. Based on past reports, most of the time your air would be closed all the way.
FWIW, our stove has a 20' flue. When burning well, the air is almost always closed all the way burning dry softwood. However, when burning very hard wood like locust, it might need to be opened a little bit. Likewise if burning just a few splits to maintain heat in mild weather. This is guided by flue and room temperatures.
Just to clarify, when you say close it all the way, do you mean moving the air control to the factory LOW (L) setting, or shutting it down completely until it can’t go any farther?
Shutting it it down all the way is on low
