they are Railroad tie end cuts....The best part it is mostly oak and I never have to fire up the chainsaw!!
I think the ties are White Oak, as well. Looks dry enough to burn today. Score, indeed...Jackpot score in my book!SCORE!
So that's two loads? OK; 4'x4'x8'=128 cu.ft. in a cord. From wiki (uh-oh)gave 50 dollars per load. The load was a semi dump box.
What size are they? Most look like cutoffs from 6x6 or 8x8 timbers. I don't think it will be quicker drying and might be slower if tight stacked. When stacking keep a little gap between pieces to allow air to circulate through the stack.I am done cutting!! I just need to drain the gas!! And there are 4 loads. So that's like 14 cords!!. I only use 4 per year. Also some of it is pretty green. Do you guys think it will dry quicker being cut like that??
I'm pushing it around with a new Holland 170. The semi just backed up in the barnyard and dumped it.If it was me Id be loading the things on a trailer one piece at a time. Do you have a loader or anything? How are you moving it?
They are Railroad ties. I'm thinking about just leaving them in piles...??What size are they? Most look like cutoffs from 6x6 or 8x8 timbers. I don't think it will be quicker drying and might be slower if tight stacked. When stacking keep a little gap between pieces to allow air to circulate through the stack.
Yeah that's kind of what I thought. Just splitting the bigger ones. Thanks for the input![emoji6]AMWESOME SCORE! I would maybe split some of the larger ones from corner to corner to end up with some wedges so when you stack it you can create some air space for drying. To flat faces stacked together aren't going to dry the best.
An outfit that makes Railroad ties for the Railroad lines. And yes I think it is the score of the year/decade!!.Where did you get them from? That looks like the score of the year!
