Look at the top most piece in my photo. The 6" stainless flue fits inside of the top ring. I did it that way so if anything drops down out of the flue it will fall into the fire box. When I run a brush down from the top of the stainless liner when cleaning,I end up with a small pile of creosote in the fire box.Robertk, did you use an appliance adapter ? or did you just run the liner over the top of your flue ?
I hope this answers your question
I'm not sure what the appliance adapter is.Gotcha, thanks for the explanation.
It sounds like then you are not using the appliance adapter and your top most ring is probably in the neighborhood of 6.25 ID to allow the stainless liner to fit inside of it.
The reasons I had to make my own adapter was lack of room above the stove and the angle which the stainless liner connected to the top of the stove. I think the diameter of the top piece is 6.75 inches to allow for the outside diameter of the flue and the angle which it entered the stove adapter. I'll try and take a photo of it tonight (before the Giants game) if no one has a fire lit when I get home.
	Thanks for the clarification RobertK, that is great work you and your son did. I am basically doing the exact thing except mine will be square at the bottom.
I do not have access to a roller to make one like that but today I found a solution online, I found a metal mart that sells all types of pipe by the inch, and they have one that should work perfect.
I took a couple of measurements on the Buck. Flue outlet is right at 8" across. The L-bolts should be able to grab anything 1.75" or less below the top of the opening.
I have flex at the bottom of the rigid liner. I got a 30* elbow, and that will go into the flue collar. The elbow doesn't fit all the way down to the ledge on the inside of the collar, but it extends a decent amount past the screw holes in the collar...
Oh yeah, I forgot about the rod...The only issue with it is that the Lopi has a draft rod (see my first photo) so I'd have to get someone to cut a notch out of this. But, thats probably cheaper than having the entire thing fabricated from scratch.
  Hopefully you can find a way to make it work.Oh yeah, I forgot about the rod...Hopefully you can find a way to make it work.
here is the metal place I was referring to above, they have some that are pretty thick walled tubing and sell it by the inch.
there is an 8 and 8.25 ID on this page below that may work for you. at least gets you closer than 8.4 ID
http://www.speedymetals.com/s-204-round-tube.aspx?pagenum=11
What do you need to fabricate ? cant you just take the pipe and weld to the top of your insert ?
with the notch taken out of course.
Yeah, the outlet in the Buck 91 is also exactly 8". As you can see in the pic in my first post, there's a step-down on the bottom of the collar where the gasket sits. The OD of the stepped-down portion is 7-7/8" so that it drops into the outlet slightly, with a little room for movement side to side. The wider part above the step-down is 8-5/8" so it sits on top of the outlet and the gasket is compressed to the top of the stove.Woody, It looks like that Buck collar has a wider diameter at the bottom than at the top. The hole on the top of my insert is exactly 8" diameter. What is the inner diameter of the bottom of that Buck collar? I'm hoping the bottom is a little wider so it will fully sit on-top of the stove itself and then taper down to 8" inner diameter to accept the stove pipe.
Redrig, Are you sure that pipe from Speedy is correct for wood stove heat? I was told by a stove manufacturer that the metal needs to be 304 or 316 but I'm not sure exactly what those designations mean----maybe he was just talking about the liner. Apparently, some metals warp over time with the high heat.
What I meant by fabricate is to have someone take a flat piece of metal and roll it to that round shape----like the previous poster did who made that fancy attachment for his insert. I don't have the resources to do that. So, buying a short piece of 8" pipe sounds like the way to go.
well that link I sent was for steel products, they have it in other types of metals, but I would assume 1/4 steel will work considering that is what your stove is made of probably, that should be more than enough.
I asked the same question in another thread and Begreen stated the 24 gauge is more than sufficient.
the 316 SS recommendation is probably for your liner.
did you check out that Ebay link ?
That's gonna leave a big gap to take care of, and a big air leak if whatever you fill the gap with falls out...short piece of iron pipe that has an inner diameter around 8-1/4"
Yeah, but as I mentioned, it's only 8-1/8 at the top, and it tapers smaller as you go down i.e. the further you push the pipe into the collar, the tighter the fit gets.Your inner diameter is 8-1/8" where the stove pipe goes into. I haven't seen a piece of pipe that has exactly that inner diameter.
does anyone know of a retangular adapter? Its on an old buck stove that measures 3 1/2 wide x 14 long. trying to connect flue to stove..Robertk, did you use an appliance adapter ? or did you just run the liner over the top of your flue ?
