Okay Guys...I've been following the posts on this site for many months now and it seems to me the scariest ones have to do with overfiring scenarios. I had a Hampton HI300 installed in my 2,000 sq.ft. Center Hall Colonial in late October. I have an exterior chimney 28 ft chimney with a 6" ovalized, pre-insulated SS liner. I haven't been able to burn much due to the warm weather, but I have some questions regarding how to avoid overfiring the insert. Here are some points I picked up by reading other posts and you can let me know what you think.
Dont's:
			Dont's:
- Avoid putting a large load of new wood on to a deep, hot coal bed since this can rocket the stove temps upwards of 700 degrees very quickly, which will be hard to control?
- Avoid loading up the firebox with lots of small, extremely dry splits which can also rocket stove temps too quickly?
- Avoid burning Pine, lumber scraps and other wood that can rocket stove temps?
- If you are dealing with an overfiring situation, shut down the air intake as far as it will go and turn the internal fan on high to cool the unit down?
- I've read some posts about opening the door in a overfiring scenario, but wouldn't that be just adding a whole lot more air and compounding the problem?
- Use a stove stop thermometer to monitor temps?
- Build the fire slowly at first to heat up the firebox...then load the firebox with large splits of seasoned hardwoods, packed tightly and slowly shut down the air intake after the fire is well established?
- After building/establishing the fire...let the burn cycle run it's course over the period of 4 to 6hrs before adding more splits?
- Let the coals burn down so you're not loading on to a deep, hot coal bed and rocketing the stove temp too quickly?
