How to burn wood pellets in 2006 Auburn corn burner
Ok. Plastic flower pot and a broken brick.
Like my wiring job? Lol. Ok, firing her up again.
  • How to burn wood pellets in 2006 Auburn corn burner
Reactions: Washed-Up and Ssyko
Just keep them from melting on the pipe.
Reactions: Rxwoman1961
Maybe close the damper by a 1/3
You dont want pellets flying out of the pot but just kinda dance till they are almost burnt up
That’s looking pretty good so far. 15-20 min into the run mode is where you want to fine tune the damper. Take the screw out half way its in to far to start with
Too much damper? Its still burning pretty good.
Open it just a tad and let it burn and make noise lol. My meds are kicking in, cant keep the old eyes open. So don’t leave it unattended and unplug everything when you shut it down for the night. Post some pics during the run so we can keep track.
I was hoping this worked , i did have some thoughts that we were chasing our tails like rick said, but now with some supervised hot burns maybe this stove won’t be in the scrap pile awaiting a new life as a bumper on a truck.
Rx before you fire it up again give the glass a wipe down so we can get a good visual of the fire.
Reactions: SciGuy
Ive been following! RX is a trooper!!! Progress is being made. I would say to start it with the damper closed a little then open it as the feed level steps up. There is a approx. 5 min delay between steps. So if it is on 1 and you want it on 4, it will take approx. 20 min. to step up to 4. That is built in for corn burning. Corn does not like sudden change. Basically as much air as it will take and still keep up with feed. Ssyko, you probably already know that, but trying to throw so info out there in case it may help.
did not know that the ramp up timing was different, mental note taken. for the next corn stove i work on;) lol
I have a heater! I have a heater!
You read my mind. Cleaned everything this morning.
Started it up and had one little hickup. I opened the damper a bit and it nearly blew the fire out!
Then the stove didnt seem to see the fire so it shut off again. I just turned it back on.
Now it fires right up. No blow dryer needed. The room fan came on within 10 minutes (used to take 30).
IMG_20210113_111654378.jpg IMG_20210113_111710490.jpg IMG_20210113_111831201.jpg IMG_20210113_112634652.jpg
What heat setting do you have it on now?
Your gonna be opening windows and doors when this gets rippin lol:)
