how many ton of premium wood pellets would equal a cord of seasoned wood?
i would like to see the math, not a calculator.
jimcooncat said:That's what I've been told as well. I just find it hard to believe that the same BTU's would take up a third of the space -- if my own math is correct.
Andrew Churchill said:Don't forget they make both hardwood and softwood pellets so I'd say a ton of hardwood pellets should be equal to a cord and a half of hardwood. But some people claim that softwood pellets burn hotter than hardwood pellets.
As a general rule one ton of pellets equals a cord and a half of wood.
Andrew Churchill said:As a general rule one ton of pellets equals a cord and a half of wood.
ugenetoo said:Andrew Churchill said:Don't forget they make both hardwood and softwood pellets so I'd say a ton of hardwood pellets should be equal to a cord and a half of hardwood. But some people claim that softwood pellets burn hotter than hardwood pellets.
shouldnt be much difference between hw and sw pellets. after processing, the density is nearly the same. the only variable would be the amount of btus released by the pitches in softwood,which should be miniscule.
ill try this myself. im sure someone will help me if im wrong.
green hardwood pulp is being measured at 5000#/cord. usually runs about 45% moisture off the stump.so....5000x.55(%dry material) = 2750 dry material per cord. add back 6% for the m/c usually found in wood pellets...2750x1.06= 2915#.
looks like 1 cord wood equals 1.46 ton wood pellets not taking into account the btu loss from the higher moisture of firewood.
EngineRep said:ugenetoo said:Andrew Churchill said:Don't forget they make both hardwood and softwood pellets so I'd say a ton of hardwood pellets should be equal to a cord and a half of hardwood. But some people claim that softwood pellets burn hotter than hardwood pellets.
The calculation looks good but the cordwood to pulpwood change doesn't work. Pulpwood is harvested a small pieces (less sawing in making paper) so there is less air space in any volume. So the 5,000# per cord doesn't work. Here's a link that gives the weight by type of wood:
http://extension.usu.edu/forestry/HomeTown/General_HeatingWithWood.htm. This shows that a cord of dry wood can weigh less than 2,000# on the low end to over 4,500#.
With minimal variation a pound of any wood at the same moisture content contains the same heat energy as a pound of another species - it is the density (pounds/volume) that varies.
And, softwood pellets burning hotter doesn't mean they give of more heat. It means they give of the same amount of heat in a shorter time.
ugenetoo said:nobody sells wood by volume any more. its done by weight. thats the only accurate way to do it. pulpwood or cordwood. it doesnt matter. a cord measure is really an outdated form of measurment due to the huge number of variabilities.
ugenetoo said:how many ton of premium wood pellets would equal a cord of seasoned wood?
Webmaster said:A ton of wood is a ton of wood (in general) - most species having similar heating value.
The correct answer to the question is: IT DEPENDS
On a lot of things - but if I had to hazard an answer on the East Coast AND with a new efficient woodstove...
It would be that a ton of pellets was about the same as a cord of medium mixed hardwoods. If a person had higher value heating hardwoods - then the ton would not even equal a cord.
On the other hand, comparing on the west coast with soft wood.....the ton would definitely equal or exceed the heating value of a cord.
sonnyinbc said:Simplistic reply. but pellet without power means no heat. wood without power still lots of heat. but perhaps more work.
Giovanni said:sonnyinbc said:Simplistic reply. but pellet without power means no heat. wood without power still lots of heat. but perhaps more work.
Perhaps? I`d say definitely! And don`t forget to add the dirt, bugs, creosote , and a huge amount of ashes.
John
!sonnyinbc said:Giovanni said:sonnyinbc said:Simplistic reply. but pellet without power means no heat. wood without power still lots of heat. but perhaps more work.
John
Well, I do recall years ago when the kids were little and the power was out for 3 days and we all moved the sleeping bags to the rec-room and slept there nice and toasty. Bugs and All!
