How to prevent cut tarp from shredding
Dmitry
1,206
CT
I want to reuse my huge somewhat worn pool cover. It is still pretty good but developed some tiny holes over the three years we used it.
It's 30' by 50'. I want to cut it and use it until I find a permanent solution. I assume the edges will shred after some time after being cut. Any tips on how to prevent it?
Good Quality Duct tape works pretty well for me. I put one piece so it folds over the cut edge and then one on either side.
Reactions: Dmitry
We use Tyvek house wrap tape, which lasts better than Duct tape
Good to -40::C to 104::C Moisture and UV resistant
Reactions: Dmitry
Thank you, guys, that’s the advice I was looking for.
I use the heavy duty silver tarps, but even those eventually shred. Duct Tape seems to last long enough .
I've used 3M "Poly and Tarps" duct tape with success. I found it at Home Depot.
If you do a piece or two on both sides of the edge, poke a hole through all the layers with a razor, then thread a zip tie through to create a loop, it makes a decent tie-out point.
Reactions: Dmitry
I get around 10 years on the silver ones.
Reactions: Dmitry
They fell apart in 3-4 years here - at least the areas exposed to sun. (Very clear difference.)
Microplastic (mm-scale) everywhere. Pissed me off big time.
been doing the same thing with bladders. I cut the top and bottom off first use that for top covers in/on the totes. totes have odds and ends in them.
Just had a tarp that was shredded, it covers my generator on my trailer. It's folded to fit so only the pouter layer was bad. We cut it down and my wife hemmed it and sewed it on her machine, worked great.
