Hi,
I have a Vermont Casting Winterwarm large insert. I need to remove the damper assembly in order to replace it. I have all the panels removed from the top, sides, back and bottom, the two bolts, and the damper arm. The damper assembly frame moves a very little, like a 16th of an inch, in and out (front to back). There is nothing obvious that I can see/feel holding it in. Is there anything else I need to do to be able to remove this damper assembly? Any suggestions appreciated. Pictures enclosed.
Thank you,
Austin
![[Hearth.com] How to remove damper assembly from VC Winterwarm large? [Hearth.com] How to remove damper assembly from VC Winterwarm large?](https://www.hearth.com/talk/data/attachments/271/271815-5dcb4d8b102237cad5342968eda8b13c.jpg?hash=Uu-4J9OhDK)
Thank you,
Austin
