Hey guys I have a question for you. Hoping I don't have a problem.
Last week I was doing my bi weekly stove inspection. I pulled the cat out of the stove to inspect and clean. I noticed the gasket for the cat was damaged. No big deal. I called up Woodstock and they very graciously hooked me up free with some rope gasket and cement. I then started having a problem when closing the cat. When i dropped the handle it the plate was rubbing stove top. I didnt think much of it as i figured i may have things poaitioned a little off. I let the stove go out repositioned and things got better. Still did it a time or two more but then stopped. This leads me to tonight. Luckily it was warm and will be warm for the next few days/week so no stove usage. I figured what the hell I'll go ahead and fix that gasket. I noticed the metal plate the cat goes into is warped. Is this an issue? It's slightly bent up. I have attached a photo of the plate. Can I fix it? Could I heat the plate with my torch and knock it flat? Is this a serious problem?
Thanks for your help!
