Got a Buck Stove 74 insert installed a couple weeks ago. I'll first admit I"ve had a HUGE learning curve and do feel like I'm learning new things each day. I first realized I was dealing with green wood, so we solved that. Then realized the splits were too large around, so we solved that. But now with good dry splits, I cannot heat the house with it. I have propane wall heaters that I have to have on along with the wood stove or the house would be too cold. The wall heaters are definitely not running as often though.
Here are my questions as to why I'm not able to heat the house with the wood stove insert alone. This model is rated to heat up to 2600 sq ft. My house is 1700 sq ft but my main living space (and where the stove is) has a 25' vaulted ceiling. I do have a couple of ceiling fans spinning in reverse for winter. Second possibility, when it was installed (by a professional), he installed it flush with the wall. He said because there wasn't a hearth, that it would look odd stocking out especially with the blower on the bottom so he pushed it all the way back. Am I losing heat from this or is this how inserts are designed to work? Would I get more heat if it was sticking out from the wall?
And of course there is the 3rd possibility and it's that I"m still a newbie at this and things will get better and I'll get more heat?
