My 028 was revving high and also idling really high. Knew it must be time to clean the filter out (something I generally do before there are symptoms)
Pulled the filter and it was horrible. I can't believe it got so bad. I cleaned it.
This completely fixed the high revs and seemed to RUN much better, but the high idle was still wayyyy out of norm. Think about something halfway between normal idle and full throttle.
So, grabbed my scrench and made some adjustments and got the idle back to where it should be. I musta made 3 or so turns on that screw.
Is a migrating screw a common problem? I'm just trying to figure out how and why it was so far out of whack. Everything is AOK now. BTW, this didn't happen slowly over time. My last session out I noticed it, and then again when I had the saw out to trim some splits down on Saturday (when I cleaned the filter, etc)
