I was worrying about putting this on the forum because I know how most feel about somebody building one of these units. But I feel I'm doing a pretty good job so here's my build thread on my boiler. I'm building this at my work place. I started in February this year. Let me know what you guys think. Any comments or concerns by all means let me know.
With what I know now I would have built a gasser but I was fully committed to this design before I came to that conclusion.
My plan was to be into the boiler for less then $1000 and then the cost of the install added to that. I'm doing all the work myself. All welding is either MIG or TIG welding. All joints are double welded where possible.
Here's some progress pics of my build so far
It started life as a 126 gallon upright propane tank. I cut the top out and started with my ash pan.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167426-d070eec766ded43395f9caaa5045d535.jpg?hash=JNr9hCU4RH)
Then I added some legs and a feed door frame.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167427-c3cd9402c1b7660924c534d0e729692c.jpg?hash=jR6pZs0113)
Added a heat exchanger adaptor to the tank and a water cooled baffle.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167428-b9bf9a7aa2f31f3e904b493eb7d84af3.jpg?hash=SywFoH7dpB)
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167429-217b3a14e43e5308c0ac2c114b5a8ab6.jpg?hash=KUylD7coik)
Built a cardboard heat exchanger template.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167430-42e572eab4cd8a248a850f0a3d4a6925.jpg?hash=5nODEYyUn_)
Then built a heat exchanger
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167431-e746439b8d1d013a2b973fc0555bbc03.jpg?hash=UoCzRRbEmY)
mounted it and started the water jacket floor. My fire box bottom will be lined with fire brick.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167432-074c6a7e955c19ba548c3a50eb44da6e.jpg?hash=k5QuaNDs0q)
Added a front and rear plate to the water jacket
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167433-bb3d14a3c2dba7d2a846c13e601f35b2.jpg?hash=C6I-04c9XF)
Flue adaptor, water ports and forced air intake pipe.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167434-80521921f3654337a7259b2c903f1786.jpg?hash=10AC_Rpo_n)
Sides to the water jacket
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167435-2f2920abb6268742e0adbf84ffef91da.jpg?hash=L1SGxtB4lb)
A front view
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167436-b741c94db3ac17554ec667757f756744.jpg?hash=EdGmoDrJla)
My fan assembly I made up
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/167/167437-c0e0b8d899e141bc5f223a02f1cd9861.jpg?hash=FXAqDHIW5-)
A front view
. If your return temps are too low you could shock the steel in the boiler and cause premature problems. Also low return temps around condensing temps could cause condensation in the heat exchanger and flue pipe causing. (Or at least that's what I've read)
