I am jealous. Specifically, I am jealous of those members who can apparently keep their homes at tropical temperatures with their woodstoves, because so far I can't do so. No doubt that's partly because this is my first year and my wood supply is less than ideal, but I suspect it's also due to the fact that I have an insert rather than a freestanding stove, and the chimney is on an outside wall. Even when the stovetop temperature is cruising over 600F (IR thermometer), it takes a long time to heat up the room, let alone the rest of the house. I suspect a fair bit of heat is making it past the air jacket and escaping into the fireplace behind the surround.
The fireplace behind the insert is an early (1950's) Heatilator-style prefab steel box. The Heatilator (actual brand unknown) had its own air jacket, which was connected to some convection vents to circulate heat into the room. The orignal smoke shelf rusted into oblivion before I installed the insert. It rusted so badly that it basically doesn't exist anymore. The back and sides of the original firebox are solid, and I did install a 22g block-off plate in place of the original damper. But what this means is that my insert is surrounded by a second air jacket which is open, thorough the nonexistent smoke shelf and the space between the stainless chimney liner and the (quite large) original terracotta tile liner, to the cold, cold sky. And that's where I think a large fraction of my heat is going.
So anyhow, I have a couple of ideas about how to improve this situation, and I'd like some feedback.
- Lay a bat of some high-temperature insulation directly on top of the insert, held back a couple of inches from the chimney connector, to reduce heat loss through the top of the insert.
- Insulate the fireplace interior by adding a second layer of sheet metal, with some sort of small spacers to create an insulating air gap.
- Finally -- and now that I write all this down this solution is starting to seem like a fairly clear winner -- dump a bunch of pour-in insulation down the chimney (*around* the liner
). Not enough to fill the chimney (it's already an insulated liner) but enough to at least partially fill in the Heatilator's air jacket and the original smoke chamber, cutting off the path to the sky.
