Den said:Dan, It's your house, your heat, and your $. The only person you need to worry about disappointing is you. . .and maybe the Mrs.Okay, so you've decided to get the T5 for ~ $3k. How 'bout taking a pause and putting as much effort into choosing a chimney for $2k? I'm sure the boomtown thing is part of it (oil $ ?), but I'm not surprised that you can't get a chimney guy out right away. It's their busy season. . .probably started getting busy a month ago up there.
Plenty of folks on here run without insulation, but I am surprised at someone being "against" flue insulation. Like I said, if your masonry flue is large enough to accept it, I see no reason to recommend against insulation, other than laziness, and ~ $200 cost, which is not very significant in a $5k project. I was not going to insulate. Some knowledgeable folks said I didn't really need it in my climate, and I didn't feel like wrestling with gluing it onto the liner and then worrying about ripping it during installation. . .then I came across the InsulFlex liner which came with the insulation already attached inside an aluminum sleeve. Cost ~ $150 more than a plain liner, and the only extra work was lugging 50 lbs onto the roof instead of 20 lbs. Both insignificant to me in the context on ensuring optimal draft in as wide a range of conditions as possible.
I would keep calling chimney guys. I have to believe that a city of ~ 1,000,000 has at least 1 chimney guy who is going to say,"Block off plate?. . .Absolutely. It's the only way to fly. Yeah, I can get out there next week. . ." In the meantime, you could read up about chimneys. That www.woodheat.org site is a good place to start.
Flex pipe? Rigid pipe? ICC, Magnaflex, Selkirk, Simpson? All kinds of choices to make!![]()
Yes, the price of oil makes/breaks this town. The price of oil is not too bad, so business is good out here in this neck of the wood (I am probably the only one on this board that wants to see higher oil prices
)In terms of what I am getting for the incremantal money is the following:
1. A rigid liner and cap
2. Demo/removal of the facing bricks (see pics on previous page)
3. Capping off the "Gas assist" in the fireplace
4. The entire install
5. Someone I can bother if things go wrong
6. There is sales tax of $250 in the quote
This guy I am dealing with is a "stand-up" guy, he is doing what he thinks is the best install (and who knows, maybe for Calgary it is). I will let you know how things go today (I am waiting on a quote from a second place for the T5 - getting this quote has been like pulling teeth, but I just want to make sure that I am not overpaying by Calgary standards, I know I am by U.S. standards)
